Hi everyone,
I'm building a KHA and wondered if there are any upgraded cam chain tensioners available?
Any other improvements to the motor I should be looking for?
Also, is the exhaust on a KH the same as the KHA?
Thanks in advance.
KHA 500 cam chain tensioner
David Smith
Re: KHA 500 cam chain tensioner
Hi you need the later solid type tensioner rather than the spring steel item . I think its available from the club scheme. I fitted one to my KH with no great problem
The modified chain tensioner is described in Waller, a copy of which is available to view in the Members Only section
of the club website.
https://www.arielownersmcc.com/members_ ... 0twins.PDF
