Accuspark on the Square Four
It's time for a new adventure - I'm searching for silky smoothness, easy starting and less rattles on the Mark 1. Actually I already have easy starting so I suppose part of this is just curiosity.
I have a positive earth Accuspark system for the distributor and I shall be fitting it over the coming days but first a question!
Does anybody know why Accuspark supply 3 different sleeves to go over the distributor cam?
The first problem to overcome is that I ordered the positive earth kit. My 4, like all my bikes is negative earth. Sometimes I wonder how I get out of bed in the morning.
dave.owen
Re: Accuspark on the Square Four
Post by dave.owen »
I have one of these bin my mk11 , the base plate fouls the auto advance, I had to relieve it to allow the auto advance to work. I have three sleeves I used the one that fitted most snug.
Dave
Was it a good choice?
Post by JohnnyBeckett »
hi , use Accuspark on motorcycles and classic cars it makes them start and run a lot better :D
Chris Sealy
Post by Chris Sealy »
I tried a Thorspark, which worked well. It also came with a choice of trigger rotors. Apparently it's because Lucas distributor cams are not all the same shape. They are all square of course, but some have sharper corners. Pick the one that fits best. It must not be loose.
Unless you have some modern electronic devices on your bike; swapping the battery terminals over will only require swapping the ammeter terminals, otherwise it will read backwards.
The ignition coil terminals should also be swapped over, in order to maintain a negative voltage at the spark plug. Cheers, Chris.
PS. It won't cure a single rattle.
dave.owen
Post by dave.owen »
I've had no running problems, easier to start ad well.
Dave
klaus gerhard
Post by klaus gerhard »
Yesterday I tried to help my friend Gerd on his 1958 Mk2 checking the ignition timing. After lifting the distributer cap we saw the very same electronic system. We were unsure how to set/check that actually. With points the timing can be adjusted with the use of a simple light bulb. How do you set this electronic system?
dave.owen
Post by dave.owen »
I set ut up with points then leave distributor and replace base plate with electronic unit.
Paul_Linden
Post by Paul_Linden »
Klaus - see this forum post on page three. It describes how i addressed the problem you describe.
viewtopic.php?p=73262&hilit=magnetic+plastic#p73262
Alas I no longer have the magnetic film.
klaus gerhard
Thanks Paul, Thats a very interesting post about the issue.
Will try it asap.
Regards Klaus
