1937 VH Parts needed
Re: 1937 VH Parts needed
Thank you Vincent for the detailed post.
I found this one attached .
It doesn't have the stiffening piece but i can do something for it. Hopefully it looks correct.
Konstantinos
Konstantinos
Yes, that looks correct, congratulations with your find!
Hello guys, can anyone tell me what is that side connection coming out of the tank i bought?
That will be the oil feed to the rockers. I guess that tank is later than 1937?
I guess you are right Simon.
The tank is a 49’
The tank is a 49’
Probably a tank from a twin, an OHV single with that style of tank would have the rocker feed from the timing chest.
(Somebody check the parts books!)
Not fatal, I'm guessing that the tanks are otherwise near as dammit interchangeable?
'55 Huntmaster, '56 VH, ' 51 VH, '61 Arrow, '80 R100RT, '00 Sprint ST (hurrah, the 4-stroke Ariel parts have managed to make a running Huntmaster!)
Still looking for a girder fork 7” front wheel hub.
hi the two little oil pipes one goes to the rocker feed and one to the rear chain guard on the later Ariels to oil the rear chain guard
