fork springcovers
fork springcovers
Hello any one had any succes finding fork spring covers. I mean the metal shrouds that screw to the bottom of the bottom yoke on my square 4
Re: fork springcovers
I've used the Hawker ones from Draganfly recently. Very nice quality.
thanks for the reply I know the dragonfly can supply these items, but they are o ut of stock and was trying to find an alternative supply as I already have a few items on back order.
hi , i found a set for my square 4 on Ebay for £10 for the pair + £4.40 pp under Ariel spares
- charles.bulloch
I have a set for sale which are attached to the yoke. They are not easy to remove.
C. Bulloch
C. Bulloch
We're they ok? I had some eBay ones with duff threads.JohnnyBeckett wrote: Thu Feb 13, 2025 5:50 pm hi , i found a set for my square 4 on Ebay for £10 for the pair + £4.40 pp under Ariel spares![]()
hi got mine of the yoke using a 1/4" drive screwdriver socket with a extension bar and i tap the bit in to the screw head and they came out if they are well rusted in warm up the yoke (i use a hot air gun ) and then some wd40 etc and try again if you take your time they will come out without breaking and the covers i got was very good and they are the right color as well
Hi thanks for all replys,especially Charles Bulloch but right at the moment I am having trouble getting the covers of my own bottom yoke. constantly on ebay but no luck yet unless bsa ones will fit anyone know?
I think that BSA covers have a slight flare on the lower edge
Looking at the BSA pics on the Dags site, they all seem to incorporate the upper covers/headlamp ears as well (which is how I remember them).
I think I've seen some HTs using the BSA covers (without the headlight) so it might be possible to arrange something, but it might also need the yoke(s) changing as well, so if it is a possibility it won't be a straight swap.
(Not an area of expertise for me so I stand to be corrected!
