Plunger to locate neutral. Leader Arrow gearbox.
Richard B
Post by Richard B »
I have found that the plunger which locates on the dimple in the change mechanism jams the mechanism. The gearbox works well without it. The engine/gearbox is from an old Leader. Was there some difference between the Arrow and Leader which is causing this? It would be good to have this positive neutral location.
Re: Plunger to locate neutral. Leader Arrow gearbox.
Gearboxes are identical. You mean the T796 plunger, try a new one, readily available
Post by will_curry »
I'd wondered if Richard could be describing a defective neutral light switch, an option for Leaders.
The switch screws into the gearbox casing by the rear suspension.
Yeah I wondered as well. Same as a Landrover part
