VB build
Re: VB build
Interesting tale. Allways nice when objects come to you with a certain story!
Re: VB build
Lovely story, I suspect that none of us passes a skip without looking inside. We were once having a big clear out at Draganfly and had a skip in the yard that was being slowly filled with rubbish and scrap parts. It was very slow because as soon as we threw something in, someone, mainly Bruce, would take it out again!
- Karol Burger
Re: VB build
Paul Slootheer wrote: Sat Nov 23, 2024 1:10 pm To be honest, I suspect deep down in all of us there’s a hoarder hiding…![]()
Ariel 500 E - 1927 /Ariel SF-1931 ,Ariel SB - 1932 / Ariel 4F6 - 1932, 1934 , 1935, 4G 1000-1939/ KG500-1948 AOMCC Slovakia Branch Secretary
- fpassmore
Re: VB build
Hah we are all guilty of having too much stored away
'51 SQ4, '56 NH, '56 VH, '37 VH500 Red Hunter, '56 SQ4 (on the bench),'49 Sq4 (basket case), '48 A7 BSA Twin, 10 other BSA's, 7 Norton's, 2 Triumph's, 2 Ducati's and 3 Japanese. Just crazed is all my problem is.
Re: VB build
Back to the build.
Picked up the other (better) cilinder, new Std. liner, valves and guides.
Surface skimmed, yummie!
Good for another 70+ years, Now I can get on with the fun
Re: VB build
Ah, that so beautiful. Perhaps you should use it as a paperweight rather than get it dirty on a bike.
That said, (and I hesitate to offer advice to m'Learned Friend) you have cleaned out the hole behind the exhaust port that's just below the 4th fin down from the top, haven't you. It easily fills with dirt and dead spiders. On my barrels it's about 5.5mm diameter and I've opened it out to 6.5mm (1/4 inch in proper units) using a masonry drill carefully. (I've found the latter necessary 'cos of the sand in the metal from its initial casting.) This cooling hole isn't on other sidevalves that I know and if you fit a VH cam, well, you need all the cooling you can get.
This hole isn't on the BSA M20 and long ago and far away when I was a teenager and knew all the answers to everything I fitted Gold Star racing cams into my M20. With an empty silence it would CRUISE at 60 - but not for long before the exhaust valve failed.
Regards from MikeN.
Regards from MikeN.
Re: VB build
I think I have been there and done that
But I'll double check !
Answer to earlier post by Paul,
This (other) 'De Ridder' WNG frame did not came via Carlo Jusche but was found on the attic of a farm in the Northeastlowland
in Dutch : Noordoostpolder
Re: VB build
Work on the VB down to a crawling pace.... December duties swallow the time in the shed
scroll sawed the head gasket.
and a question:
would it make sense to take away the sharp edge (round of) to 'lower' the heating up around that area ?
or is this a hypothetical (aka as complete bollocks) idea and a solution to nothing ?
I figured that because a VB gets pretty hot around that spot to take away the sharp edge.
(I've learned from my glassblowing days that sharp edges heat up much quicker compared to rounded ones)
and a question:
- Karol Burger
Re: VB build
It's an interesting idea, but it probably doesn't make much sense, even though the chamfered edge could affect the flow of the fuel mixture, which would improve the engine filling, it won't guarantee you great success in acceleration. Reducing the rider's weight helps more (my own experience
Users browsing this forum: No registered users and 63 guests
