I've been asked to commend this bike.
Looks not bad in my eyes, what does the specialists think?
Markus
1933 VG at Yesterdays
- markus.nikot
AOMCC German Branch Secretary
some Ariel - only Ariel
Re: 1933 VG at Yesterdays
Engine and frame numbers match. There are a few things I would suggest are incorrect but they are minor - the panel light should be painted black as an example. But they certainly want plenty of money for it.
A rare machine, let down by a few minor points, as Paul says, mainly the finish on a few parts that should be black, the style of tank paintwork is debatable. Front brake rod is a bit long and the rear brake arm is at a very ineffective angle not helped by the odd shape of the arm. At least the front brake rod is in the right place. Silencer brackets! Lower chainguard, speedo cable is broken, gear control rod should be straight, side battery strap should be turned round, strap screw is wrong, petrol pipe aaargh, ex lifter cable is the wrong way round. The fork damper knob is a very rare part as it only lasted one year being replaced by a large wing nut from 1934.
For that money I would expect perfection.
- markus.nikot
Thank you both. I have forwarded it and will keep you posted. Maybe we will get a new club member.
- markus.nikot
The VG is now in germany and I expect a new member for our club.
Markus
Markus
- Karol Burger
that's good news. new members are an asset to the community. Not everyone is active, but one in 10 surprises with their actions
It's just over 90 years old now. Getting thinner on the ground. . Nev
