Ariel Four
jehagadone
Re: Ariel Four
Post by jehagadone »
Crankshaft gear tools.
jehagadone
Re: Ariel Four
The 400052 distributor rotor is backordered.
Is there a Lucas car distributor rotor that is the same or will work ?
dave.owen
Re: Ariel Four
Post by dave.owen »
Austin 7 would work
jehagadone
Re: Ariel Four
Dave,
Thanks for the info.
I found one in the usa !
jehagadone
Re: Ariel Four
Please id these foot pegs
Rubber has Britax London
https://live.staticflickr.com/65535/540 ... 9bb6_h.jpg[/img]
jehagadone
Re: Ariel Four
jehagadone
Re: Ariel Four
Which wire is field, left or right ?
Re: Ariel Four
Those Britax passenger footrest are typically fifties generic parts, perfect for your SQ4.
Picture with all the loose parts shows the 'AVC cover part 6170-37
- I sometimes wake up in the night having again dreamt about it :lol: -
Good to have as it's one of those tiny parts that are the icing on the cake :D
AVC cover 6170-37.jpeg (64.82 KiB) Viewed 1663 times
Chris Sealy
Re: Ariel Four
Post by Chris Sealy »
[/img]The Lucas C35SD, has the field connection on the right. Cheers,Chris.
jehagadone
Re: Ariel Four
Vincent,
Chris,
Thanks for your help.
I found the special bolt and acorn nut for the oil line in my box of parts Tuesday.
I found the short line for the oil pressure gauge and the oil line fitting for the head in my box of parts Tuesday.
I looked for distributor rotor two times, not found, today it appears.
Can you identify any parts in this photo ? (coil cover top right).
