Amal carb 276B/1J as fitted to 1946 NG
Akumar
Post by Akumar »
Dear fellow enthusiasts,
I am recommissioning this 1946 NG. While cleaning the carb, I noticed this little hole in the flange. Please see the highlighted yellow circle. What is the purpose of this hole? It must weaken the fuel mixture. Should it be plugged?
Thanks for help.
50 NG, 53 VB, 58 Colt
Re: Amal carb 276B/1J as fitted to 1946 NG
I have seen these holes before, it is not a later addition but I don't know what they are for. Probably it is specific to a particular model. What is the number stamped on the flange, I should be able to find out what it was originally used on?
Akumar
Post by Akumar »
Hi Roger,
The carb is stamped 276B/1J
chris.shearwood
Post by chris.shearwood »
Hello Atul,
That carb number goes with a 1940-45 350cc Matchless. I don't know about the hole in the flange.
Regards, Chris
Sorry, I noticed later that you had the carb number listed in the subject line, then couldn't find my index to carb numbers! Looks like you will have to get onto the Matchless forum, if you find the answer please let us know.
Don't think the little hole will make a lot of difference. Just tune the idle. The Military G3L has a smaller carb than the ARIEL from memory.. Nev
