1930 model G pushrod tubes.
Hi, are the pushrod tubes for the model G, push in or threaded into the head.cheers.
- chris.vredenbregt
Re: 1930 model G pushrod tubes.
Push in they can turn freely make sure to seal them in the head .....Chris
Thanks Chris.
I seem to remember that Merv Kendall had overhauled a few G engines and said that he'd seen both types. Possibly they changed during the production year so keep an open mind about this.
Moto Guzzi V7 Racer Mk2 (ABS)
AOMCC Member 3400
AOMCC Member 3400
Thanks Dave, I have ordered a set of push in tubes from Pat the forgeman.
Yes I've seen both types. my 1930 has the threaded ends. I don't know how the others stay in place, unless they rely on the fit. Nev
The head of my motor came away freely, I assumed they were pushed in and put the head on again, I should have checked but was more interested in the state of the bore.
Clearly that type does rely on the fit. The lower ends are slightly reduced in diameter for a small distance.. You would have to align them to the holes in the aluminium sheet cover as they are a "reasonable" fit. The original breather (oiler??) is clearly in view there. It lets stuff in, not out. (as I see it). Nev
Thank you Nev, I may end up using the old ones after a clean up in some evapo-rust.
