1939 XWD 1939 VH maiden voyage
- alan.moore
With the sun shining brightly I took the old war horse out for her first run since the full rebuild / restoration. After the wet sumping issue I had yesterday (after she had been standing idle since being first started up last November) she pumped the 'sumped' oil back in about 15 seconds and, once on our way and warmed up, ran smoothly (once I worked out I was using the choke lever back to front )
This is the first bike I have ridden with manual advance and retard but I soon got the hang of retarding a bit as I came up to junctions and temporary stops in traffic and then advancing as I pulled away.
I was impressed with the action of the girder forks. The spring stiffness appears just right, and to tell the truth I never really gave them much notice. The seat was nice and bouncy, and I certainly need to tone my butt cheeks up after the winter layoff.
Brakes...well they were relined by Villers with their woven linings 'designed for classic bikes' and were centered when installed... following the advice given on the forum. At first they did do something, in that I could stop at a junction, but most of that was engine braking. After twenty odd miles they are getting better, but I think a session of fettling of the trailing shoe length is needed. They just feel very wooden, with no real increase in retardation no matter how hard you pull/press the lever.
Gearbox was lovely, smooth changes and no crunching as long as you took a bit of time to make the changes. Box has a 50/50 mixture of SAE50 and normal lithium grease. Clutch was smooth and light (club linings, Drags plain plates and a nylon lined cable).
As it has a new piston / rebore (+40), new crankpin and mains I am at the running in stage (SAE30 oil). But the old girl just wants to go. I have not been above 1/4 throttle (honestly ) but there is so much torque she pulls like a train. And the sound through the Armours high level pipes is a joy, I am sure the shoppers on our sleepy high street were well impressed... well they all looked as I thudded by on half retard.
Oil pressure on the gauge is about 7 psi when warm and at travelling speeds, so maybe needs to be adjusted up a bit (Waller says 10 to 15 psi).
having got back I noticed only one real oil drip (result ) from the banjo where the oil pipe for the rockers comes off the stud on the front of the timing case. I tried to nip it up but something was clearly wrong...the thread has stripped inside the timing case...bugger.... Please have a look at my post in the four stroke section to see the problem, and hopefully with the forums help, the solution. (see this post http://forum.arielownersmcc.com/viewt ... 236#p63317
Here are a few photos taken today
Alan
Alan
- chris.vredenbregt
Re: 1939 XWD 1939 VH maiden voyage
Lovely bike Alan these singles are really a joy to ride...Chris
Glad you're happy with it after all the hard work, excellent piccies, is that your front driveway?
- alan.moore
I wish Simon...I think its called a photo opportunity rural gateway
Lovely bike, lovely weather!
Singles are great fun. Old biking without the worries of a '50's multi...
- alan.moore
Here are a couple more photos taken today. I really like the sepia ones, looks much more period:
Alan
Alan
Well done Alan - now get down seriously to wearing it out !
- Steven.Carter
She looks absolutely lovely.
Steve
Steve
- Eero.Korhonen
It looks very good and weather too.
Br, Eero
Br, Eero
- Leejm
Excellent Alan, will we see it at the agm!?
