Hi All,
Can anyone help with a RH footrest - the one with the big curl under the gearbox.
Thanks,
Richard
Western Australia
1938 4G: looking for a RH footrest
- Richard Kal
Re: 1938 4G: looking for a RH footrest
I've been looking for one for ages. too. Manx Classic Spares in Ballarat may have them in cast high strength bronze. Nev
Could you fabricate one from bar stock? Two pieces, one bent bar with the taper/threaded end, welded to a second piece, with a turned internal taper.
Yes you can do something like that. I don't even have an example to copy from. The military bike uses the same both sides as is done on some other models also. You do get a better clearance of the gear foot control lever with the "special" RHS footpeg. . IF you set the arm into the tapered section tapered to a point into one side, and vee out all around a nickel bronze weld (braising) will be stronger than mild steel. nev
- paul.wirdnam
For the average person that would be a good idea. looks like a "class" job. and it clears the gearbox well . It's further back than the alternative offerings so the short gearlever will work fine. Had a quick look. Need to translate . What sort of money? Emma Chisit? Nev
- Richard Kal
Thanks for the advice everyone; Karol to the rescue (again) - footpeg in the post on its way to Western Australia!
