W/NG timing chain
Re: W/NG timing chain
I have a better one for you with the same casting number for 25 pounds + 20 pounds sending..
- alan.moore
Adrie,
In photo number 2 is that a brass washer over the crankshaft oil feed pipe /quill . I have the same cover but have not seen a washer/spacer like that in the parts lists /
Alan
Alan
- alan.moore
Luis,
I wonder what others think about using the split pin to secure the half link to the chain. I think it may possible catch on the oil pump as the chain goes around. Could you peen that link pin over rather than using the split link?
Alan
Alan
It's someones idear of a oilseal, i have bought it this way.alan.moore wrote:In photo number 2 is that a brass washer over the crankshaft oil feed pipe /quill . I have the same cover but have not seen a washer/spacer like that in the parts lists /
- alan.moore
Interesting, is there any advantage in such a seal given that you cannot produce any oil pressure against a roller big end bearing?adrie.degraaff wrote:It's someones idea of an oil seal, i have bought it this way.alan.moore wrote:In photo number 2 is that a brass washer over the crankshaft oil feed pipe /quill . I have the same cover but have not seen a washer/spacer like that in the parts lists /
Just a comment .that is a nice cover but is the 39 and earlier type that must have the pressure adjustment stuff complete in the upper hole or the oil will not be fed to the big end. Nev
- LuisPaz
Hi Alanalan.moore wrote:Luis,
Alan
There is space behind the oil pump. No problem i think with the split pin.
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
