W/NG timing chain
Re: W/NG timing chain
It's standard chain for older pushbikes. Doubt they used half links though and I think one is necessary. I will double check today time permitting. Nev
- LuisPaz
Hi Nev!
I found this bicycle chain kmcchain.us/chain/hl710-silver/
Can one of your half links be used?
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Checked today all mine and you have to use a 1/2 link and it will have to match the chain.. I can't see how you could reasonably make one that would be reliable . Nev
- Eero.Korhonen
- LuisPaz
Thank you Eero for the link!
After many telephone calls and consultations, I found a seller of industrial chains and he offered me this half link.
Maybe I can rivet and not use the lock pin ..
What do you think?
What do you think?
1944 Ariel WNG
1944 Ariel WNG
- alan.moore
Have a look at this post. http://forum.arielownersmcc.com/viewt ... ming+chain You will see in my photo that the chains have one 'cranked' / half link which gives the odd number of links (35) required.LuisPaz wrote:Hi Nev!
Drags and John Budgen both do them
Just saw your last post. If you can rivet that link i think it should work OK
- LuisPaz
Thank you Alan for tha usefull post!
Next Saturday in my workshop I will try to build the chain with the parts that I found here in my country.
As a last resort, I will have to buy in the EU/UK.
1944 Ariel WNG
1944 Ariel WNG
- Eero.Korhonen
I think it would work fine, if you have right amount of links.
Br, Eero
Br, Eero
Line the magneto up carefully when you put it on and get the tension right. They don't give a lot of trouble but swapping joining links etc for different makes of chain you often get a variance in the pin diameters. Nev
- LuisPaz
Thanks for your recomendation Nev!!
I will take it in count!
I've been thinking about using only the middle link and not adding the split link...
1944 Ariel WNG
1944 Ariel WNG
