Page 1 of 1
Turning nipple end cable
Posted: Fri Nov 09, 2018 11:43 pm
by LuisPaz
A little work with my 180 x 300 lathe
Materials: Old Key
Re: Turning nipple end cable
Posted: Sat Nov 10, 2018 2:08 am
by nevhunter
IF it's made from some of the high strength bronzes that have aluminium in them, it won't tin with solder. Check before you get to that stage. How do I know? Had some "Y" shaped fuel junctions cast and nothing you do will make them tin. Luckily I didn't machine all of them up before I found this out. Counter sink the thick end so you spread the cable strands so it won't pull out when you want to stop quickly. Nev
Posted: Sun Nov 11, 2018 1:00 am
by LuisPaz
Hi Nev
Thanks for your recommendations and comments!
I made the solder in the nipple and it was very strong.
The decompressor works correctly with new lever.
