Simes' FH Rebuild
Re: Simes' FH Rebuild
No prizes for guessing where this magneto is going. The slip ring is broken too - it turns, so hopefully the armature is not broken...
https://youtu.be/-CN5nVRPVkc
- Eero.Korhonen
A "bit" messy I think.
Br, Eero
Br, Eero
Chaps,
I'm struggling with the dynamo pinion. I've had the puller on it with a bit of heat, but it's not budging. Am I missing something?
- Steven.Carter
Put the pressure on, then give it thump.
And lots more heat
. Use a much more substantial puller. Put a good load on it and heat the sprocket as quickly as you can then tap the bolt on your puller with a hammer sharply. Leave it tensioned and it may just come off by itself. A lightweight puller is no use with this sort of application. The best pullers have a fine thread on the bolt that applies the force. Nev
And it's off:
Took me a while to find the time to make the puller.
Have a close look at the oil pump - there is something sitting on it:
Any ideas what it is? Bit of the ATD unit?
Any ideas on the mysterious bit of debris folks?
In case you were wondering what I was up to, I've been messing around with a recalcitrant parts washer pump. Next job is to finish my gudgeon pin extractor, make a puller for the camshaft pinion and think about how I'm going to remove the crankshaft pinion.
Any advice on that one?
