I am in the process of sorting the rear mudguard of my 1951 NH. It is the 1950-type with the folding rear section. Thinking ahead to re-wiring, can anyone advise of the route of the wires to the rear/brake light? There appear to be two clips on the inside of the offside rear mudguard stay - was that to hold the wires, or do they run up and under the mudguard? If they run up the inside of the rear stay, how do they get there? Also, they run under under the hinged section, so presumably there must be enough slack to allow it to hinge upwards - but doesn't this result in them rubbing on the rear wheel when slack?
Advice (better still photos!) appreciated.
Wiring route for rear lamp
- James Hickman
'50 NH 350 (Shiny)
'29 Model B (Oily Rag)
- charles.bulloch
Re: Wiring route for rear lamp
I got fed up of the wires under the mudguard of my 55 NH becoming disconnected. Instead of using bullets I ran 3-core flex to the lights along the frame tube and fitted quick release connectors. This gives a proper earth.
Charlie
Charlie
The wire(s) run up the inside of the offside stay and you need a connector in the wire when you lift the hinged section. The big problem is with the stop switch which is on the left side with the brake pedal, requiring a lot of wire down to and from it, which looks messy. Nev
