Primary Drive Chain Case Hole
Re: Primary Drive Chain Case Hole
You are missing that plate. If you seal the dome you could operate the cork clutch wet . That's probably not easy to achieve with only a few screws holding it on. The plate is quite complex and not easy to make especially if you don't have one to copy from. Nev
