VG barrel/piston/conrod query
Hi, building a ‘48 ish 500 single with parts from a variety of sources. Crank is VG with the rod (A7/524), also found in VB’s. Apparently this is longer than the VH rod ? I have assembled it with a new VH piston, but the piston protrudes above the barrel around 3mm at at TDC. Did the VG have a shorter crown height piston ? Can’t find anything to differentiate them in the Drags tech pages, they recommend the same piston for VG and VH.
My barrel could have been shortened but I don’t think so, the base flange is 23mm thick, from the base surface to head surface is 134mm, and from base to top of spigot is 137.5mm. I can easily make a Packer for under the barrel but I’m curious to know where the extra 3mm is from ?
Thanks
Thanks
Re: VG barrel/piston/conrod query
The VB rod is longer (and heavyer) so you need to find a VG rod.
You could opt for the stronger a VH crank and rod.
According to the Drags info charts, the A7/524 rod was used in both VG and VB ?
That should be VG and VA.
A VG rod is aprox. 190mm centers and a VG crankpin is lining with the brass crankcase cambaring, when the pin is higher you have a VB crank in it.
Thanks Adrie. I have to deal with it as it is, I have just had the big end replaced in the rod/crank
- dave.owen
I have 2 spare VG cranks, both have A7/524 conrods
Dave
Dave
Thanks Dave, maybe mine is the correct rod then ? Do t suppose you have a VG piston that could be measured ?
- dave.owen
I run both my VG and VH on the same pistons. Both barrels are the same. 24 mm base flange.
Dave
Dave
Thanks again. Maybe my barrel has been shortened? Does anyone have an iron 500 barrel they could measure please ?
Just measured an NH barrel, it is 10mm shorter than this VG one, which is what you would expect ? The mystery continues
Users browsing this forum: Ahrefs [Bot] and 35 guests
