Wanted aluminium push rods
Wanted aluminium push rods & battery older for a 1957 red hunter please
- john.nash
I did this.
Mark where the end sits on the rod; so you'll know how far down it should go, when you knock it back on.
Little bit of heat and then gently tap the ends off - using something softer than the ends (or rods) - I think I used another bit of ali.
When putting the ends back on, mark the rod so you know where it should sit, then again heat them up a little and tap on.
Push rod length from Draganfly: http://www.draganfly.co.uk/shop/pi-9958 ... egoryId=87
Re: Wanted aluminium push rods
Hi John,
Thank you for that I will have to give it ago and dragonfly will no the length you said.
Regards Tom
Regards Tom
- john.nash
Click on the link, that I put in the post, here it is again:
bottom of the page .. pushrod lengths ...
