W/NG Front Brake Cam
- LuisPaz
Hi Fellows
I make and easy drawing and i need measurements to make my own front brake cam.
Can tell me any measurements with a letter?
Thanks in advance!
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Re: W/NG Front Brake Cam
I'll see what I can do , Luis. OK here it is.
A = 1/2 inch diameter
B = 1"
C = 1/2 inch Cam width.
both washers one fixed and one floating are 1'5 mm thick and 30 mm dia which is also dimension D.
Thread is 5/16 x 26 tpi thread, 8 mm long. Square is .390 inch across flats 5 mm long and 10 degrees anticlockwise of the faces of the cam to position lever alignment correctly.
Adjust B length to get correct end float and allow for washer. Sorry about the mm and inches mix.. Conversion is 3937.( 1 mm = .3937 inches . Good luck. Nev
B = 1"
- LuisPaz
Hi Nev! Thank you very much!
Now i have lathe work for the next weeks!
1944 Ariel WNG
1944 Ariel WNG
- LuisPaz
Today I started to build the cam
A scrap bolt turned into brake cam!
it remains to adjust and finish ...
1944 Ariel WNG
1944 Ariel WNG
Don't forget the square on the end is displaced about 10 + degrees to get the brake arm in the correct position. They MAY be slightly tapered. That would get a better fit. The "fixed " washer is rivetted on. You leave a small extension. Hope it's not to late for that one. Nev Nev
- LuisPaz
No late Nev!nevhunter wrote:Don't forget the square on the end is displaced about 10 + degrees to get the brake arm in the correct position. Hope it's not to late for that one. Nev Nev
I have that info...
But now i need pics ansd measurement to make the brake cam bush...
1944 Ariel WNG
1944 Ariel WNG
There's no bush as such. The cam turns in the floating "bracket" P/n 4130-32 held in place with two 1/4" bolts P/n 0531, 2 stepped nuts P/n 4132-29 and two Thackery washers . The holes at each end are elongated to allow movement for the shoes to centre when the brake is applied. It's fabricated by welding but you could make it from solid mild steel (or even bronze).. Nev
- LuisPaz
Yes Nev , is bolted and floating.. thanks for the bolt measurements!
1944 Ariel WNG
1944 Ariel WNG
- LuisPaz
I keep moving slowly, adapting parts that have to be twinned, it takes time.
1944 Ariel WNG
1944 Ariel WNG
