My new projekt/bike 55 SQ 4 MK ll
Just to say hello to all in this great Forum.
Here my new passion, just arrived:
Cheers Rudy
Cheers Rudy
1923 James Model 12 500ccm v-twin -- 1960 Chevrolet Corvette C1
1926 Douglas EW 350ccm flat-twin -- 1967 Chevrolet Corvette C2
1936 Motosacoche 500ccm single --- 1979 Chevrolet Corvette C3
1948 BSA A7 500ccm parallel twin -- 1955 Ariel Square Four MKII
- Steven.Carter
Re: My new Projekt/Bike 55 SQ 4 MK ll
Hi to both of you looks lovely
- Eero.Korhonen
Wow, that is great, hello and welcome!
Br, Eero
Br, Eero
Looks great. Is she registered already?
Good luck and lets wait for spring to come. Klaus
Hi Rudy, looks lovely. Do you have an air-cleaner in place? The routing of the petrol pipe from the O/S of the tank looks odd. When you say 'Projekt' what needs doing?
Looking more closely, do you have a petrol tap on the N/S? I think the usual arrangement is a three legged brass? piece with the pipes dropping from each tap to meet under the carb and then to the float chamber.
Best regards Roger
Best regards Roger
Thank you all for the warm welcome.
@ Klaus: Spring may be real, at the moment only with red number
@ Roger: Yes in 62 years of use the old lady experienced obviously some changes.
Thank for explainig me the originally routing of the fuel lines. At the moment there is only 1 petrol tap.
And yes I have now an aircleaner on the bike.
I also have made some further minor improvements:
May be coming soon:
Best regards Rudy
May be coming soon:
Best regards Rudy
Re: My new projekt/bike 55 SQ 4 MK ll
When was the engine last rebuilt, and perhaps more importantly, by whom?
Hi Roger,
I was assured that it was 3 years ago, only a few hundred miles since then.
But when I have the chance to get an Coupling gear Extractor (or a drawing of this) I'll do the job by my own only to be sure......
http://forum.arielownersmcc.com/viewt ... =11&t=7475
Best regards Rudy
Best regards Rudy
- Bob.Murphy
Now that is going to be very effective (maybe a bit too much so) as it has full compensation between the shoes. I would suggest a decent 'pull-off' spring or a sprung sleeve between the levers as there can be excessive 'Self Servo' with this set-up .rschurr wrote: May be coming soon: Rudy
A common arrangement is for the cable to pull on one lever while the other is operated by an adjustable shaft. With this arrangement it is difficult to keep both shoes operating with the same pressure so it can be less effective.
My "MkIV Lester Grant" TLS Brake fitted to my 'VH':
I'll be very interested to hear how it performs on the road.
(And others will no doubt chip in with their experiences ).
Hi Bob,
yes I hope this brake will be a little bit crispier than the Ariel "FullHub" brake. It is from a BMW R50-R69S and it is indeed a little bit tricky to adjust. One of the levers has a adjusting cam, you had to fix first, the second will follow. Your tip with the spring between the levers may helpfull, w'll see.
On my BSA "Longstroke" A7 I installed a brake similar to your "Lester Grant". Works really fine.
Rudy
P.S. you have a PM from me. Thanks again
Rudy
