Oils for 1942 W/NG
Oils for 1942 W/NG
Hi all,
Next question for you, what oils are recommended for Engine and Gearbox on the W/NG. Book says 50 HD for Engine and C 600 for Gearbox.
What do you all use?
Mike
Mike
1942 Ariel W/NG 350cc
1960 Ariel Leader 250cc
1963 LE Velocette 192cc
Re: Oils for 1942 W/NG
I've got Morris SAE 50 in the oil tank, and a 50/50 mixture of Castrol LM and Morris SAE 50 in the gearbox.
Morris SAE 50 (again) in the primary case.
this I use, gearbox and engine.
Thank you Vincent
- LuisPaz
Hi Simonsimon.holyfield wrote:, and a 50/50 mixture of Castrol LM and Morris SAE 50 in the gearbox.
Maybe a stupid question, but how do you do the mixing? Outside gearbox in a bottle or inside gearbox so that the moving gears make the mixture??
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
Outside - makes it easier to get the mixture in the gearbox.
Get a battery drill and fashion a type of crude egg beater set up. Keep it warm and it will pour. Has to be thin enough not to channel. Check it by running in a gear on the rear stand if you are worried about where it ends up level wise. Nev
- LuisPaz
Thank you simon a nev for your reply!
Oil and grease quantity?
Quantity or level?
Quantity or level?
1944 Ariel WNG
1944 Ariel WNG
According to the W/NG factory Book, 2and 1/2 inches below filler orifice. Mix external and add grease to the oil constantly mixing till it thickens but still just runs at normal temperature. I don't know the proportions as it varies with the ingredients you use. Use a gear oil and a high temp grease . Some greases are thicker than others. Don't trust it to mix in the box as it may block oilways, particularly to the layshaft bushes. Nev
just to be different, the p/o ran mine on diesel detergent oil, he fitted a return oil filter and I have continued with this practice, I have taken her to the Irish rally and Latvian rally as well as quite a bit of running around and club runs, she seems to be quitter happy with this oil. kind regards
