Since 2016 I am busy with the restauration of a WNG, which was imported from Myanmar to the Netherlands in 1993. Since then the bike was stored in a barn. In 2015 a friend of me, bought the bike together with a Matchless 3GL from 1943.
The dismantling of the bike is complete now, so from now on I hope to find the spare parts that I need. In the past time I already finished the restauration of the magdyno and the Burman gearbox.
I am looking in these months for parts for the engine, Girder suspension and frontbrake. So if someone can help me further? Please contact me.
Henk van Dijk, Middelburg, The Netherlands.
My 1944 350WNG
Re: My 1944 350WNG
Exactly which bits ?
I think the club does the front brake plate and maybe some of the engine bits ?
The single spares chap sometimes has girder fork parts but that aren't too common ..
c
c
Administrator
webmaster@arielownersmcc.com
Re: My 1944 350WNG
Hi John,
Thanks for replying.
I need a lot I think. For the engine following spareparts list sept.1944:
the big end complete no. 1080-29; the timing pinion no. 1770-34; woodruff key's S18-1; small end bush no. 1130-33; circlips no. 1716-31;
lockwasher mainshaftnut no 1299-28.
Frontfork: ballrace crown no.4820-36 (2); 4815-31; 4818-31; 4 bushes 0.608"; star washer.dummy no.no. 4668-35; felt washer no.4838-31 (2)
The inner drum is 1 1/8 inch deep. So I am looking for the linings no.4106-32 has to be 7/8 inch wide. With 1/2-inch shoes no.4106 32 to fit on the brake cam no.4115-36 . I also need the return springs no.41110-30; the cam, lever and rod. But the complete anchorplate would also be fantastic.
For the time being till the next fase of my project.
With kind regards,
Henk.
With kind regards,
Henk.
Re: My 1944 350WNG
In a general sense the engine parts are just NG. You might consider replacing both cam gears at the same time if you are interested in quietness.. Nev
Re: My 1944 350WNG
Nevhunter, thanks for your advice.
Henk.
Henk.
