Page 4 of 4
Re: Hole in the primary chain case
Posted: Sat Sep 16, 2017 1:05 pm
by Simon.Gardiner
In the interests of pedantry (or possibly to make sure your chain person doesn't send you the wrong thing, as happened to me)
This is a half link:
- chain-half-link.jpeg (5.01 KiB) Viewed 10080 times
And this is a cranked link (a.k.a 'a link and a half')
- chain-cranked-link.jpeg (4.54 KiB) Viewed 10080 times
Posted: Sun Sep 17, 2017 1:45 am
by ray.tolman
Thank you David and Simon.
It is good to know I made at least one good choice.
Thanks for the correction, Simon. It is a cranked link on the Iwis chain.
Ray
Posted: Sat Sep 23, 2017 9:21 pm
by Dave.Barkshire
Just a foot note to report some success!
With the nuts and tab washer reassembled correctly and also with the spring cup being tapped gently into place I now only have only one spare thread showing. The inside of the chain case has had its weld high points ground down and all was reassembled.
It started first kick (they all do that sir) and I did notice that the primary case dome became warm instantly but with no noise. I think that there might have been the slightest contact at first but it all seems to be ok now.
I did notice that the clutch basket is quite slotted so I will look for a 'new old stock' item to replace it.
Today I've had several rides through the Devon countryside up and down hills and nothing has blown up. The new piston and valves are all swishing away like a Swiss watch and apart from the need for a little clutch adjustment the whole plot seems very happy with itself. Brakes are very powerful, the handling and steering are very natural and the overhauled charging system and magneto are all spot on.
Hurrah! Happy Arieling to you all.
Posted: Sat Sep 23, 2017 9:26 pm
by roger.fellows
Well done, Dave!
Posted: Sat Sep 23, 2017 9:36 pm
by Steven.Carter
Great stuff. Its lovely when it comes together.
Steve
Posted: Sat Sep 23, 2017 11:04 pm
by chris.shearwood
Hi Dave,
Congrats on getting your bike repaired and back on the road. Don't forget about Feked when it comes to clutch parts.
https://www.feked.com/burman-clutch-hub ... -boss.html
Regards, Chris
Posted: Sun Sep 24, 2017 2:19 pm
by Simon.Gardiner
The photo Feked have for the 'Ariel heavyweight' clutch centre is for the 5-plate 350 clutch.
The photo on the 'Panther heavyweight' centre looks more like the one for the 7-plate 500 clutch.
Have they just got the photos mixed up 'or what'.....
Posted: Sun Sep 24, 2017 2:31 pm
by Dave.Barkshire
A couple of hours in the saddle to Appledore and back in torrential rain and nothing went wrong. Hurrah again!
On strange thing... the clutch center was running off kilter. I removed it and re-assembled. It's a mystery that something which fits straight onto deep splines could ever be 'off'. Anyway, the clutch is much improved and lifts almost square now.
Note to myself : Never tickle the carb after a lunch stop when the engine is still warm.
