Hi When I log in all the times on the forum including the current time loose an hour. As they return to correct time when I log out its not really a problem Just wonder why it happens. Is it something I have done? or not done.
Thanks Paul M
Forum Time
Re: Forum Time
Have a look at your forum timezone setup. Assuming you are in the UK and your computer is set to "(UTC+00:00) Dublin, Edinburgh, Lisbon, London", your forum timezone will currently show UTC +1 (because we are in BST at he moment).
Your forum timezone is set up in your user control panel, board preferences.
Re: Forum Time
Thank you for explanation Simon. It had to be my fault. Will try to fix.
Thanks Paul M
Thanks Paul M
Re: Forum Time
An admin can do that for you, if you need help.
