Front Brake Cam Lever
Has anyone got one of these folks? It's a straight arm, PN 4141-40 and has the swivel end set up to accommodate the flats on the brake rod.
Re: Front Brake Cam Lever
I got one from Drags last year for the 4G. You might have to adjust the alignment slightly but it works well enough.
- dave.owen
I also had one from Drags for a single with girders.all brake parts are also available
Dave
Dave
Do Drags brake levers have a round hole for the rod? I have a cranked lever on the W/NG at the moment, which has a round hole.
I believe that the lever should be straight, and have a slot to prevent the brake rod rotating?
My lever, ex Drags, is slotted but has a round hole on the top side to part way through. The slot only exists for perhaps a third of the total length of the hole, as per the originals. I assume the slot going only part of the way through is for ease of manufacture but I suppose it could also be to allow a small amount of rotation before the brake rod has to bend if the joint between pin and arm becomes solid.
Excellent. Thanks for your help Paul - I will order one.
