Have had the petrol tank restored
Now the paint is coming off around the filler neck
Has anyone else had this problem with new paint work !
Just removed the tank only to find there is a leak from the bottom
about half way between the mounting bolts right hand side
taking the tank back to them on Sunday to be repaired
Watch this space !
( you only find out how good a company is
when things go wrong .)
Square Four Petrol Tank Restored
Re: Square Four Petrol Tank Restored
Paint coming off round the filler neck is best avoided by using a machine with a tank panel. My panel tank machines are no problem but with the others it seems to be just a question of time, if you use cellulose paint, as I do. But the non- panel tanks are dead easy to re-spray......
Still watching this space Marcus!
1958 Huntmaster
1960 Matchless G12
1958 AJS 18s
1960 Matchless G12
1958 AJS 18s
Hi John yes still here
Going to leave the petrol tank for the moment might get it restored properly by Lewis Templeton in Coventry .
