WNG
WNG
Hello.
Can some one tell me if this holder has bin fitt on Ariel WNG ?
In advance thank.
Jorgen
In advance thank.
Jorgen
Re: WNG
this is the BSA one.
My Ariel came with one like yours but I have the push button switch present (ammeter blanked - push button where switch was).
I do not have the under seat switch though.
Happy to swap for something ?
The parts list (original copy I have) for my bike, still shows the original switch and not this late war one.
Administrator
webmaster@arielownersmcc.com
Re: WNG
John, you show a picture of an M20 with the under seat switch. Interestingly the pic shows a canvas seat cover. Do you know anything about this bike and the history of the seat cover? Almost no expert admits that some WD bikes were fitted with canvas covers.
Re: WNG
Nope.wade.edwards wrote:John, you show a picture of an M20 with the under seat switch. Interestingly the pic shows a canvas seat cover. Do you know anything about this bike and the history of the seat cover? Almost no expert admits that some WD bikes were fitted with canvas covers.
I linked to a couple of handy pictures off the WM20 site/forum just to show the switch arrangement
I have a canvas seat cover on my bike too.
Mind you, I don't really mind too much about originality (or cleaning)
Administrator
Re: WNG
Canvas is cool with me. It's the extremephile rivet counters that rained on my parade when I thought of covering seat frames with canvas. Still might,
Re: WNG
Does anyone have the under seat bracket properly mounted to their W/NG? I am now interested in using this option for the 44 W/NG I am doing and would like to properly locate the ammeter braket. That is, if I had a bracket. So far I have two, four position WD switches, but only one CZ27 ammeter. I can use the proper ammeter on the 42 W/NG I am also doing.
One CZ27 ammeter went for GBP 155.00 today and I don't want to make another investment like that. It would be less expensive to go the no ammeter route.
Re: WNG
I will answer my own question as I've found the picture John has used. It is from the BSA M20 WD forum and is listed under Electrical in the Technical section.
In place of the light switch was fitted a large black bakelite "push" button, marked on top "P" (for "push"). On pushing this button the rider changed from main beam to low beam, and vice-versa). With the ammeter missing, the idea of this system to see if the dynamo was charging was to turn the switch to the "test" position and to rev-up the bike's engine. If, on doing this, the tail-light bulb was seen to glow brightly, then the system was seen to be charging.
Re: WNG
"In place of the light switch was fitted a large black bakelite "push" button, marked on top "P" (for "push"). On pushing this button the rider changed from main beam to low beam, and vice-versa). With the ammeter missing, the idea of this system to see if the dynamo was charging was to turn the switch to the "test" position and to rev-up the bike's engine. If, on doing this, the tail-light bulb was seen to glow brightly, then the system was seen to be charging".
Re: WNG
Here is what I have
I do not have the underseat switch or box. I checked my pile of switches and I do not have one with "test" on it either (a few with the additional "c" and "t" )
Administrator
