The new Project
Re: The new Project
You had me stumped for a short time with that one Jerry but I think it would be early 1973 when the final shape of the petrol tank was being determined. the bike would almost certainly have been the prototype. The fuel tanks were made by the late Don Woodward but his son carries on the business and has sent me photos of a tank he still has. You will note a wooden strip down one side of the underneath of the tank. If you take this tank, including the wooden strip and apply the wooden strip to both sides you end up with the final shape of the petrol tank. This is why I think the date would be early 1973 or so when development was almost finished and production about to start.
Could this be what you saw?
- jerry.mortimore
Re: The new Project
Could be. I always liked green and I remember thinking if I could ever afford one I would have it in green like the bike I saw.
Re: The new Project
Advice needed please. The Healey has BMC pistons which have a smaller gudgeon pin than Ariel ones. Hence I need to bush the small ends of my new Club con-rods.
What interference fit would the panel recommend for a phosphor bronze bush going into the alloy con-rod? Diameter is approx 11/16" or 17.44mm
Re: The new Project
Found another (very small) picture on the Bonhams site
Re: The new Project
At the recent Annual Rally, one or two members were kind enough to enquire about progress on the Healey. The answer is that progress is there, but slow. However, recent work on the forks enabled me to use a technique for removing bushes which I had known of for years but had never found an excuse to use.
The top fork bush (Metal Profile forks) is Teflon lined and pressed into the slider: So, you make up a fairly tight fitting plug, fill the fork slider with oil, insert the plug and hit with a hammer: The hydraulic action of the oil under pressure from the hammer blows extracts the bush - if somewhat messily ! Note the long lasting AOMCC 2003 Annual Rally t-shirt !
Re: The new Project
I bought one of these sets - it would have been less messy and is also good for many other applications
http://wondermantools.co.uk/16-pc-piece ... es-puller/
I think I paid around £35 for the same set from the bay of E
Re: The new Project
4 years ago, almost to the day, I was packing the crate with the burnt out bits:
Today, I took it up and down the road for the first time:
- Steven.Carter
Re: The new Project
4 years?, where did that go..
She looks stunning Paul
- fpassmore
Re: The new Project
That is lovely looking bike. Great job you have done with that burned out reclamation.
Frank
Frank
