Outer cable speedometer drive
Hello,
I am looking for outer cable speedometer drive. It should be similar to a shower hose.
Do you know the supplier? I would buy this outer cable, "in meters" selected by myself length.
Kind regards
Kamil
Kind regards
Kamil
Re: Outer cable speedometer drive
If you want a second hand outer for a PA speedo, I am sure I have one or two. Contact me off line.
Can I assume that you cannot get new inners for them.
I am still running the original cable but it has a spot where rust has got it so it ticks and shakes the speedo. I am reluctant to get a repro cable if I can resurrect this one.
Ian
Ian
Also, John Budgen sells new PA speedo cables.
http://www.johnbudgenmotorcycles.co.uk/speedometers.htm
Moto Guzzi V7 Racer Mk2 (ABS)
AOMCC Member 3400
AOMCC Member 3400
Thanks . but I only want an inner, as I'd like to keep the original outer if I can. Other wise I'll wait till this original breaks before I buy a repro one which I expect I can get from JJ cables near me.
Ian I can always
Ian I can always
JJ cables supply good quality cables for PA speedos. I know of another supplier whose cables have, on occasion, wrecked a PA speedo in about 50 miles flat, presumably due to the connection at the speedo end not being fitted squarely. I therefore recommend JJ cables for PA speedo cables to the exclusion of all others.
Many thanks for a help. It's very usefull. My SG31 in on good way. Soon I will put new pictures of the progress.
Kind regards
Kamil
Kind regards
Kamil
I had a rust spot on my original Ariel PA speedo inner cable. I wanted to keep the original type not a modern type.
I got a new inner made to pattern for about £25 by
www.speedograph-richfield.com/
Ian
Ian
