Hello,
I am building a 1928 500 ohv (and have been since time began...its the reason why I joined the AOMCC in 1996 or 7ish) - I have most of the bits but the oil union on the timing cover confuses me - my timing cover has a threaded insert upon which I guess some kind of banjo fitting should attach the bottom end of the oil feed pipe from the oil tank. The oil feed pipe has the hollow banjo type fitting but I am at a loss as to what the fastener looks like.
Can anyone shed any light on what should be there? And does anyone have a spare (or know where I can get one)?
Cheerz.
Tony
1928 500 Timing Cover Oil Union
KOBI
Velocette MAC, KSS Mk1
- barry.swanson
Re: 1928 500 Timing Cover Oil Union
...hi Tony, are you able to post a photo of the threaded insert and its location in the timing cover?...B.
You can see the oil feed connection above the hole where the oil pump goes.
KOBI
Hi Tony
Have a look here: http://www.arielownersmcc.com/members ... on%205.jpg
Here is a nice drawing of it. The one in the photo must be broken or wrong.
Knud Degnbol
Knud Degnbol
Thanks Knud. I've actually found an elbow fitting that will go on the threaded bit sticking out of the timing cover. I seem to recall it was on there when I got the pile of bits which formed my 1928 Ariel starter kit.
KOBI
