E3 charging miracle
- markus.nikot
E3 charging miracle
The charging of the dynamo fitted to my sloper is a miracle. It a refurbished, original Lucas E3, runs at 6 volts with an electronic VregII regulator.
Off the bike, D+F connected, battery attached the dynamo motors at 6 and 12 volts very powerful in the correct direction. Fitted on its position revving the Ariel - nothing to read. Check with D+F connected attached a bulb or voltmeter - nothing. Splashing via F, no result.
If it motors powerful everything, rotor, field and brushes should be OK - or am I wrong?
Any suggestions?
Markus
Any suggestions?
Markus
AOMCC German Branch Secretary
some Ariel - only Ariel
Re: E3 charging miracle
Remove the dynamo from the magdyno and see if you can rotate the fibre gear wheel by using your finger. If you can't, re-engage the dynamo gear part way, remove the spark plug, rotate the engine using the back wheel and see if you can stop the dynamo rotating by means of a small screwdriver blade in the gears. That is the only way I know to check the slipping clutch on the magdyno without taking the magneto off the bike.
If that is all ok, check the wiring to the regulator, particularly the earth. Run a wire from the earth terminal on the points end of the magneto to the regulator to be sure.
Re check that the dynamo turns the correct way when it motors. Re check that the regulator is positive earth if the dynamo is and similarly the battery.
Check that the dynamo brushes are not sticking at all.
Check that you haven't overheated the dynamo and thrown the solder from the commutator. It will work as a motor if you do this but not as a dynamo.
If that lot fails, come back for more suggestions, or leave the thing alone for a few days then creep up on it when it isn't expecting you and have another go.
- markus.nikot
#Paul, it is the early magdyno without clutch.
Checked as advised, put new brushes in and everything seemed still ok but when running the engine still no charging.
Next action was dismounting the dynamo and drive it with a drill, D+F connected and attached to a voltmeter it shows at full speed which is 2650rpm bit more than 8Volts, even a bulb glows - that's good. The voltage rises very slowly but I think it works and I was only fearful to rev the Sloper high enough for a proper reading.
Think the dyno produces enough power for my usual LED daylight.
Merry christmas
Markus
Merry christmas
Markus
Leave the lights on overnight then try it with the flat battery !!
Not fully flat is better. Is everything in the field circuit normal? The magnetism there controls the generators output and the residual magnetism (sometimes missing after repair or long period idle) gets it started. Lift the cover of your voltage regulator and watch the relay points pulling in. They should do it at a bit above idle speed. Nev
- markus.nikot
Markus I note also the regulating is done with diodes I presume. That is fine as long as they have a good heat sink. There are different ways of powering the field coil. You might get a voltage reading (but low current) with NO power applied to the field coil, just from the residual magnetism. The field wiring can be 2 ways IF one end is attached to the +ve brush the regulator will control the voltage to an earth, or the opposite will apply. The current through the field controls it's output, as it did with the 3rd brush set up. Nev
