Crank thrust washers
When building up an Arrow crank can someone please tell me if the crankpin's should be pushed fully down to "nip" the triangular thrust washer so it doesn't move or should it be left so it can rotate?
Re: Crank thrust washers
Evening,
I've just checked the only built up crank assembly I can find and the triangular washers are fixed but the con-rod still has a little side ways clearance.
I'll let others answer as well so you get an answer based on other crank assemblies not just one.
Regards Brian.H.
Regards Brian.H.
