No Drive in top gear
Hi, I wonder who can guess the answer to my problem.
I finished the Levis Trial on my 35 VH last weekend with no problems. The next time I took the bike out was last night and after 3 miles , I felt a tug at the back end. Couldn't see anything wrong so carried on another couple of miles before the drive in top gear ceased with a high pitched grating howl.
I stopped and found that the primary side is OK as it kicked up again no problem. The clutch is still attached as it was possible to free the clutch and select a gear but it would drive OK only in the lower gears.
I shall be dismantling it next week to find out.
Ian
Ian
- robjameson
Re: No Drive in top gear
I suspect that may be a bush working it's way out of where it is supposed to be and stopping the gear from engaging cleanly
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
The big nut at the chainwheel for the rearchain might have come lose.
No, a bit more serious than that, The broken bit of tooth obviously got caught and then split the box.
Now to start seeing what bits I have to build into another box, I already have a casing.
Ian
Ian
- robjameson
Geoff brown might be able to help if you get stuck.
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
Check run out of shafts after that sort of thing has happened . The are usually bent. Nev
- Keith.owen
Oh Dear!
I suppose the only consolation is that the rear wheel didn't seize, or if it did, not for long enough to cause you any physical harm.
Keith
Keith
Keith Owen
Editor Cheval de Fer
1950 Rigid Ariel VH
1950 Rigid Ariel VH
No, the wheel didn't seize at all in fact I rode on for a couple of miles before I could find somewhere to pull in. I think I could probably have ridden home in 3rd gear, in fact I might as well have done as there wasn't much of the gearbox that was re-usable.
Ian
Ian
- Keith.owen
Hi,
I lost a tooth on the sliding gear in my CP. Fortunately, the tooth simply ended up suspended in the grease without causing further damage. That said I was never aware of it happening.
I guess this sort of thing must be pretty rare though. These boxes were used by Vincent so are pretty sturdy, as well as AJS. It is however a sobering thought since, the box can't be disengaged from the rear wheel as it can from the engine, by the clutch.
Keith
Keith
Keith Owen
1950 Rigid Ariel VH
1950 Rigid Ariel VH
