Cibie 12v headlight
- robjameson
Cibie 12v headlight
My headlight stopped working this weekend, and I am very aware that the reflector in my headlight is in awful condition. It seems like a good time to replace it, and I'm wondering if anyone has used the cibie kit? I'm running 12v and easily balancing power at 30mph plus using a Paul goff 35/35w halogen bulb, so my main concern is whether the 60/55w h4 bulb in the cibie unit will overload my charging system and cause problems. Any thoughts, is it worth it or should I just get a replica lucas unit?
Rob
Rob
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
Hi Rob, 60w would be using all you could produce.
There are 6000k HID and LED kits that use a lot less - I think 30w, or even 20w for LED.
See entertaining youtube clip. http://youtu.be/KtXcS-2VTzc
- robjameson
Re: Cibie 12v headlight
Reading up on the hid it sounds like a great idea. I know from a previous Steve carter post that the h4 size bulb doesn't fit in a pre focus light unit, so perhaps a cibie unit with the hid is the best option.
Any thoughts anywhere?
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
- Steven.Carter
http://m.ebay.co.uk/itm/281363715688?tx ... 6228354018
Have a look at this Rob. I've ordered one. Should be interesting
Yep, I was looking at them too Steve. Could just be the duck's nuts for those of us with the short gennies.
It would be awesome if you make a Youtube clip with a dicky accent, lots of gadgets, a bald cat and a hybrid car... - but failing that, just a report would be nice...
- Steven.Carter
Re:
When it arrives I'll do all of that!!brenton.roy wrote:Yep, I was looking at them too Steve. Could just be the duck's nuts for those of us with the short gennies.
- Eero.Korhonen
Hello,
I did install led's to VH. I ordered some cheap ones from China and Hongkong
and modified headlamp one to fit to original place.
Here is picture:
http://aijaa.com/odwSy0
Br, Eero
Here is picture:
Br, Eero
This one looks ok too. Too cold to go out an measure it up, but assuming it can be made to fit...
The data says 6v-36v. 6000k is a bright white light.
LED Headlight 6000K 18W Hi 12W Lo Light For Harley Kawasaki
http://r.ebay.com/apRkzv
- Eero.Korhonen
It's about 17€:s, not bad at all.
-Eero
-Eero
- robjameson
Because I need a new reflector unit I'm reluctant to buy a lucas unit and have to modify, I'd sooner buy a more modern 7'' unit.
These are the sorts of set up I'm looking at:
http://www.ebay.co.uk/itm/310540714720
http://www.ebay.co.uk/itm/330709113918
Rob Jameson
1957 Ariel VH
1954 Ariel KH
1957 Ariel VH
1954 Ariel KH
