Anyone with advice on how to fix transfers, I have purchased the following from Drags but I am unsure what type they are when I look at Drags instructions ie water slide, spirit fix, varnish fix, dry rub down, tacky back or sticker.
TRA 51 - Minimum oil level
TRA 52 - Maximum oil level
TRA 45 - Ariel works etc
TRA 46 - Horse and horse shoe
is there anyone with advice who has fitted these before.
John Palmer
Fixing transfers.
- robjameson
John,
They are usually water slide, and normal practice is to slide them on, let them dry and they paint over with a clear lacquer (mine is some humbrol stuff from a model shop).
A '55 nh wouldn't have had a maximum oil level transfer though I don't think.
Rob
Rob
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
Re: Fixing transfers.
Thanks Rob I will try one as a "water slide" fixing, also I will relook at the "max oil" transfer.
John
John
Have finally identified the types of transfers, the TRA 45 Ariel works etc is a Waterslide type and the others are a Dry Rub Down type as Ian stated, whether the types change depending where Drags gets them from is something worth considering.
John
John
