timing
Posted: Sat Jan 11, 2014 11:08 am
by toms.goss
I have just rebuilt 1957 350cc redhunter complete engine rebuild and runs sweet when started, to start it is the problem when i retire the spark she will still kick back you have just got to put weight of your boot on the kick start and she will kick back i have checked the timing over and over with other people, also checked the advance & retire working all right it seems like it fires at the bottom of the stroke. I have checked the valve timing and that's seems alright. It starts and goes like the clappers. its just the kick back when retired. I have scratched my head that much i have gone bald so if you can help please it would much appreciated
Posted: Sat Jan 11, 2014 11:20 am
by nevhunter
IF it keeps kicking back it is too advanced. That's it. Run about 35 degrees full advance. Start with about half of it . Nev
Re: timing
Posted: Sat Jan 11, 2014 12:20 pm
by toms.goss
nevhunter wrote:IF it keeps kicking back it is too advanced. That's it. Run about 35 degrees full advance. Start with about half of it . Nev
cheers Nev will give it ago
Posted: Sat Jan 11, 2014 11:35 pm
by nevhunter
the VH engines are pretty good at kicking back if the spark is not in the right place. The 350 is usually much less of a problem in that regard, but anyhow the timing has to be right to perform as it should. Nev
Posted: Sun Jan 12, 2014 9:21 am
by ian.scott
Have you set the timing correctly, identifying if the mag is advanced with the cable slack or tight ?
Ian
Re: timing
Posted: Mon Jan 13, 2014 3:28 pm
by admin
high compression pistons can kick back way quite a way before TDC ...
Posted: Mon Jan 13, 2014 4:12 pm
by PeterW
I'd double check the timing to make sure that when the lever is fully forward it sparks just before TDC & then watch as you pull the lever back to ensure it then fires later. You might have timed it on full retard by mistake (easy to do as the mag spins the wrong way) or have the wrong mag so pulling the lever back is advancing it, not retarding.
