Not exactly a post about Ariels but relevant to some of the older veteran machines: I'm restoring a 1910 Humber 200cc side valve lightweight. The bike has a pedal arrangement for pedaling and starting the engine. My problem is the chain is missing and it's a long obsolete type. According to RM Fowler - specialists in obsolete chains, the original appears to have been 3/4in pitch with rollers about 3/8in diameter and just over 1/8in wide.
One option is to commission a new chain at a cost equivalent to the GDP of a medium sized country or grind off the sprocket teeth and graft on sprockets and use a chain from a moped which won't look right.
So my question is does anyone know where I can find the correct chain or have one made at a reasonable cost? Alternatively can anyone recommend a chain which will 'look right'? Thanks for any help!
Veteran Chain
Veteran Chain
1939 600 OHV 4F, 1956 MKII Square Four, a Healey, 1939 OH 250, 1939 OG 250 plus a couple of OG250 projects, 1920 Ariel V twin project and a variety of lesser makes
Thanks Nev, I thought at first it was a block chain but RM Fowler, after looking at the chainwheel and rear sprocket said it's an early roller chain of very unusual dimensions. I was hoping a period Humber bicycle chain would fit but unfortunately they're not the same.
Thanks Nev I didn't know that - I will look for a couple of block chains of the right dimensions. The National Cycle Museum is in Wales so I may take a trip over there with my sprockets to see if they can help with identifying a suitable chain.
