Hi All,
Measured the voltage on the 6 volt battery on my Arrow and found it to go between 7 and 8.5 volts depending on engine speed. This means that at 50 mph the battery, coils and everything else is being subjected to a voltage more than 30% above rated. Fitted a Pazon voltage regulator to replace the rectifier and now everything has stabilised. Volts now between 6.5 to 7.2 only regardless of engine speed. Right on spec.!
Garry
Voltage regulation
- Roger James
