Amal are re-making the flame trap/filters
john.nash
Post by john.nash »
FYI.
Burlen are re-making the flame trap/filter.
Couple of layers of gauze they tell me. I have an original on my 1940 enfield and the jetting didn't require altering (after all it's not a proper filter as such)
http://amalcarb.co.uk/pre-monobloc/76-2 ... embly.html
chris.vredenbregt
Post by chris.vredenbregt »
I use them to keep the rocks out and if you spray some chainoil on it it even filters some dust out of the air,btw the originals were of aluminium...chris
adrie.degraaff
Re: Amal are re-making the flame trap/filters
Post by adrie.degraaff »
chris.vredenbregt wrote:btw the originals were of aluminium...chris
And steel, I have one with a loose inner part that will fit 276 and 376.
Steven.Carter
Post by Steven.Carter »
Cheers for that John. I'll get one for my wng
Steve
barry.swanson
Post by barry.swanson »
...what do they do that prevents or "traps flames"?
pete.collings
Post by pete.collings »
I think that the mesh interupts the flame front from a spitback through the carb,and dissipates the heat within the flame. I guess it is not totally foolproof, but should substantially reduce the risk of your carb/bike catching fire.
In old fashioned coal mines (and newer ones?) a Davey lamp was used that had a very fine metal mesh totally surrounding a flame, that prevented any fire damp (or methane gas) from igniting. Electrical equipment underground in mines had to be enclosed in a sealed container with any gaps being 8 thou or less, as this was taken as being too small for a flame front to pass through. Any ex miners out there in the forum might be able to better explain this than I can.
A flame trap isn't foolproof. (It only traps flames). Look up Davey safety lamp. The principle is fine cold mesh that a flame won't pass through.(usually brass). If it heats up it doesn't work. I know of about at least five bikes that have been seriously damaged by being lit up by a " flame back" My words because backfire is something else. engines that have a "dead" spark are more likely but a little spit back through the carb will do the trick.. Nev
