Sq 4 MK1 SHOCK ABSORBER
malcolmm
Post by malcolmm »
The crankshaft splines are worn on the end . but the bush that goes over it the machine spline internal are about inch long
Do you if they sell a bush that has internal splines the full length. The shock absorber has two lobes.
Thanks Malcolm.
Re: Sq 4 MK1 SHOCK ABSORBER
All the re-manufactured ones are the same as the original.
