SPARES
SPARES
Hi all , I'm new to this site so please bear with me . I'm in need of a engine sprocket for my sq4 .Is there a particular place on this site where spares are found .
Many thanks Tony
Many thanks Tony
Re: SPARES
hi Tony welcome to the forum you need to be a member of the AOMCC to access the clubs parts if you have joined the club you need to get your name change to red
Re: SPARES
Hi Johnny I have joined the AOMCC last week , got confirmation yesterday. Does it take a few more days maybe for the red name change to happen? .
Re: SPARES
To get the coveted red name you'll need to contact the Forum admin.
Re: SPARES
hi Tony do as Will says
Re: SPARES
Done that Will , been texting via email with a Simon G .Guess it's just takes a bit of time.
Re: SPARES
Your application goes to Roger who will process it and once that's done Simon
can confirm your membership and amend your Forum details accordingly.
There may be several cups of tea involved . . .
. . . once your membership card and Cheval turn up you'll find the contact details for
the Square Four spares organiser.
What sort of 4 have you got? My solo Mk 1 has a 25 tooth engine sprocket and is if anything
slightly over-geared for the Chiltern Hills around where I live.
- dave.owen
Re: SPARES
As long as you have the passwords as printed in cheval you can access the members sections of the website
Re: SPARES
Will , I also have a solo Mk1 . I believe it originally had a sidecar combo thus why its so low geared . Was told the 25 tooth engine sprocket was the most standard.
Re: SPARES
If I remember correctly the 'official' sizes were 24 teeth for solo work and 22 for
sidecar. Mine had a 24 tooth sprocket when I got it in the late 60's and I fitted a
25 tooth sprocket when I rebuilt it about 20 years ago.
Although now slightly over-geared and once again in need of workshop attention to
finally fit the club conrods and the repaired Solex carb it was a pleasant ride until I
had issues with the Solex and replaced it with an Amal concentric. I also like the
look of them.
Do you know much of the history of your four 4?
look of them.
