'39 Sq4 side stand retaing clip wanted
Hello
I need a retaining clip for a '39 4G Sq4 side stand. Part number 2462-33. They do not appear to be available from Draganfly, and are not listed on the club's Sq4 spares list. Anybody got one sitting around they want to get rid of?
Thanks. Ray
Thanks. Ray
Re: '39 Sq4 side stand retaing clip wanted
hi Ray if you have no luck with the forum, try looking on Ebay you may find one
I'd attempt to make one. Alan Moore did some very good posts on making W/NG fields stand springs which would show you what to do.
Thanks for the reply Johnny and Simon. I have not had any luck with Ebay (does anyone know how to filter out all the Little Mermaid paraphernalia when searching Ariel parts?). I am expecting I will have to fabricate the spring clip. Fortunately I was a metalworker in a past life.
Ray
Ray
The fun bit is getting the temper right - I had two goes at that with the stand springs. The side stand clip might be easier (as it's a bit smaller) but I found controlling the temperature across the whole spring simultaneously quite difficult. I've used a domestic oven for things like knife blades and other cutting tools, but the tempering temperature for a spring is obviously much higher.
- Karol Burger
there is some sort of side stand on my SQ4 /1939. I'll take a photo for you. If it's the right one you need, we can make a vikres for the missing part.
- Karol Burger
this is what i have on my 1939 SQ4. I don't know if this is the part you need.
Hi Karol. Thanks for the reply. The original factory side stand fits on the right side of the front engine plate and folds back parallel to the lower frame rail where it is held in place by a spring clip retainer (the bit I need). There is a photo of the clip on the main chat forum, but I'm not sure how to get it here...
Ray
Ray
- john.davies
This is the clip that Ray means
viewtopic.php?p=92552#p92552
Karol's side stand looks like the modern Royal Enfield stand that you can by off Ebay and adapt to fit, a number of other people on this forum have done this. Details here.viewtopic.php?p=92552#p92552
Thank you for posting the photo and for the information John.
Ray
Ray
Users browsing this forum: No registered users and 38 guests
