Gearbox Noise
Re: Gearbox Noise
paul.jameson wrote: Mon Jan 08, 2024 7:40 pm If you talk to AOMCC gearbox spares I suspect you will find he can tell you what you need to know if you can't find it in Waller.
Thanks Paul. Turns out I must have trawled the gearbox section in Waller - I wrote down all the tolerances and end floats in a blog post when I built that gearbox 10 years ago...
I'm losing my marbles!
Re: Gearbox Noise
Post by JohnnyBeckett »
hi, just get on to Geoff Brown at the clubs gearbox spares if he does not know, no one will know
Re: Gearbox Noise
JohnnyBeckett wrote: Tue Jan 09, 2024 7:01 pm hi, just get on to Geoff Brown at the clubs gearbox spares if he does not know, no one will know
Thanks for the tip Johnny; co-incidentally I had half an hour on the phone with Geoff this morning.
The service we get from our club is simply astounding, and better than most modern bike dealers - not to mention spares prices!
Re: Gearbox Noise
Latest on the noisy BA in my Mk1. End float on the mainshaft, 40 thou; layshaft, 12 thou; selector shaft, 10 thou...
All way beyond spec, but I have a suspicion the gearbox sprocket is loose, so I will look at that (I have a new clutch centre to fit anyway), fix it if necessary and measure all the end floats again before I go any further.
paul.jameson
Re: Gearbox Noise
Post by paul.jameson »
I wonder what you have as a gasket between the kickstart cover and the main gearbox shell. There were some pretty thick gaskets for that joint about a few years ago but it should be a thin paper one.
Re: Gearbox Noise
hi when i rebuilt my gearbox with all new parts from Geoff at the club spares , the clubs thin gasket made the kickstart and gear change stiff :o and i had to get a thicker one from Drags :D
Re: Gearbox Noise
The latest news is that the BA gearbox from my Square Four is now stripped and washed out. If you recall, some dogs were clattering at idle, in neutral.
For the record, there's 0.88 mm (35 thou or just over 1/32") end float on the main shaft and about 0.23 mm (9 thou) on the layshaft and selector. I've improved these numbers from my previous post by fixing the DTI more securely. There's no gasket fitted between the inner cover and the shell.
The worst damage I have seen is on the layshaft clutch first gear dogs and the layshaft first gear. This is always noisy going in; my clutch basket isn't brilliant and I have a new one to go in. The clutch drags when hot and I think that's what causes this damage.
The selector forks are straight and have a nice sliding fit, minimal play, in the mainshaft sliding gear and the layshaft clutch:
Here's a video looking at all the gears:
VID_20240123_174017.mp4
(263.61 MiB) Downloaded 29 times
As to the rattling/clattering at idle, I'm not sure. There's a lot of end float in the layshaft and selector shaft (Waller says 1-2 thou minimum but doesn't define a maximum) which could give rise to this clattering -particularly if one shaft goes one way and one the other, but although the mainshaft float is at the end of it's limit I can't see how that would cause the noise.
Grateful as always for your advice!
Re: Gearbox Noise
That noise could be coming from the clutch plates.
Assemble everything in the intermediate cover and move the selectors to go through all the gears and see IF anything gets close to tipping some other Part it shouldn't . Nev
Mick D
Re: Gearbox Noise
Post by Mick D »
Hi Simon
Did you check out the condition of the selector mechanism as suggested?
How worn is the main shaft small, (kick start end), bearing? I don't think that's the cause of the noise but could be contributing to the end float.
Re: Gearbox Noise
Not yet Mick - basically I only had time to pull it out and get it clean. The forks look good and they are a good fit in their grooves; they move easily on the drum but I haven't had the pins out yet.
Users browsing this forum: simon.holyfield and 16 guests
