Can anyone recommend a machine shop that can do all the work rebuilding my 1952 MK1 4G.Engine
In the north west area.
Thanks Malcolm.
Machine shop
Re: Machine shop
Do you want to deliver your engine to someone and then pick it up later, all ready to put into the bike and run? Such places are none too common. If you want someone you can take the cranks to for regrinding and the cylinder for reboring, I am sure local members will be able to advise.
A lot of people are very reluctant to strip a Square Four engine and then reassemble it. But with guidance, (and the necessary tools) it isn't too difficult. We all had to do it the first time on one occasion. I would suggest a very good first port of call could be the Lancs Branch AOMCC meeting.
The colour of your forum name suggests you are not an AOMCC member. If you are not, join the Club as it is the best investment you can make in restoring your bike. Once a member, don't be afraid to ring the numbers in Cheval to ask for advice as that is why we publish our numbers there.
Re: Machine shop
Yes I am a member .
I have stripped down the engine it needs timing side plain bushes doing not sure yet if it needs a crank grind
It will need a rebore.
Thanks Malcolm.
Thanks Malcolm.
