37 BrakePlate and Chainguard wanted
markus.nikot
Post by markus.nikot »
For a 37project I'm looking for a complete brakeplate which fits to the girder fork. Including shoes, springs, adjuster etc. If n/a parts will help too.
And an upper chainguard for a rigid frame #5720-37
Bildschirmfoto 2023-11-11 um 11.34.55.png (19.55 KiB) Viewed 343 times
Thanks for looking
Markus
AOMCC German Branch Secretary
some Ariel - only Ariel
volker.halbach
Re: 37 BrakePlate and Chainguard wanted
Post by volker.halbach »
The main difference to later brakes is that later hubs from 1938 on are 1/8" wider. I have adapted later brake shoes without problems (and then got the linings bonded *and* riveted). The spindle for the brake cam has the separate bearing 4130-38 from 38, but to my knowledge that doesn't make any difference. So you can use all the later parts, as far as I know. Draganfly should have everything. I just would be cautious with brake shoes with linings that are only bonded.
paul.jameson
Post by paul.jameson »
The brakeplate on my 4G was damaged in the collision and will have to be replaced. It looks likely that a new one will have to be made. Would you like me to get another made for you?
