Late Clutch Centre 3355-57
Posted: Sat Oct 14, 2023 7:58 am
I need some advice on my clutch, please.
Is it essential to use clutch centre 3355-57 if a later clutch drum with friction inserts is fitted, or can the earlier type with the 'tags' on which the first plate abuts be used?
Can the earlier clutch centre with 'tags' be modified so that it fits in the same way as the later type 3355-57? (i.e. grind away the 'tags,' or are there other differences between the earlier and later clutch centres?
