Otto Head Gaskets
Otto Head Gaskets
Before I replace the head on a Mk2 Square Four, is there a need for gasket sealant, other than the bead of silicone around the pushrod tunnels, as recommended by Bruce Longman?
- Paul_Linden
Re: Otto Head Gaskets
No other sealant needed, other than what Bruce says. Remember that it should be a copper based sealant, which is more expensive but worth it as it doesn’t dry out in the tube when you use it again in a years time.
Thank you, Paul.
