Thank's for advise Nev. Maybe i used the wrong expression.
Pretty sure i did compress the spring enough.(picture attached)
Then i blocked the sprocket under the shock absorber unit against the sprocket under the clutch basket with a sufficient long piece of metal.
So i could give the half time pinion nut a left turn till the shock absorber starts to move.
Ralf
Half time pinion nut
